Wakeup interval bugged
I cannot save any settings as the wakeup-interval says its maximum value is a large negative number. This is with firmware 0.9.995, I was getting NO_MOTION every minute with 0.9.994 (all with an Aeon Multisensor which worked in the past)
So how is it for others?
Same problems?
I did not upgrade yet...waiting for some infos.
Same problems?
If I plug in the Aeon Multisensor then it works a lot better than 0.9.994 (which reported NO_MOTION every minute) but on battery you can't save settings due to the GUI wakeup-interval bug mentioned above.
Actually with 0.9.995 it is sometimes only reading temperature and not the other values so something is still messed up :-(
Ok I'll stay away from it untill it is fixed.
My Zipabox also runs on version 0.9.995
I removed the Aeon Multisensor, then added it again and now the configuration option to set Wakeup interval is not there anymore.
Now I also get only temperature and movement readings. No humidity, no luminance.
Funny... my aeon labs, avfter a battery change, is reporting just the MOTION status and not any more the NO_MOTION. Also the temperature, humidity and luminance are messed up in the dashbaord events.
I have no clue on how to solve this :(
The box is now reporting changed values to server, and the rules are triggered on changes only. So you won't see NO_MOTION in the log for every interval, and we won't store petabytes of closed doors and no motions in the database.
Bindings, thermostats and alarms still get everything.
I am running 0.9.998 and I can't set the wake up interval on my multisensor. I have tried to re-apply device descriptors. See attached picture. No vaule I enter gets accepted.
Any comments, Zipato?
