Set all thermostat in vacation mode
Guest shared this idea 12 years ago
it could be nice to be able to set all the thermostats at a time for vacation ! :).Thanks you
If you create a alarmzone called vacation and put it in a rule, you could easely switch between normaly mode and vacation mode.
That should work.
Thank you for your answer.
So I can do the same with a virtual switch, don't you think?
how can we switch to vacation in a rule ?
Create a vSwitch Home/Away
Create a rule:
When VSwitch = Any
IF = vSwitch=ON = Action (vThermostat ) Set Preset Away to Away
ELSE = Action (vThermostat) Set Preset to Home
You can each room 1 by 1 to both sections IF and then ELSE
See attached.
