Zipabox won't store fibaro dimmer configuration
Andy shared this question 7 years ago
I've bought several fibaro dimmers and placed them behind my switch. Everthing is working fine but i can't change the status for the switch type. I want to change them to bi-stable. When i change it and press save it automaticly change back to mono stable. Can someone help me with this problem?
Hi Andy,
As I already mention, you need to click on the parameter name so additional buttons can show up.
/7ce03adf1782dcc11082880c95b0b677
Kind regards!
Hi Andy,
You need to click on the parameter name so additional buttons can show up. After you select the value, press SEND. After the configuration is successfully sent, Save and Sync.
Kind regards!
Hi Paula,
Thanks for the reply. I don’t see any sendbutton. The only thing i van press is the save button at the top. But when i press that the state is set back to mono stable.
Hi Andy,
Kind regards!
