Use door sensor as gaz meter reader
PeterB shared this question 7 years ago
I have a door sensor lsmt-606A from DI-O (433.92MHz) setup and connected to a gas meter. It's able to pickup the magnet every metercube of gaz. But at the moment it's setup as a door sensor, I would like know how I could set it up as a gas usage counter.
Is there a trick to force the door sensor to act like a gas counter under Zipato?
I don't think that is possible. But you can do the following:
1. Create a virtual meter which will act as your gas usage meter.
2. Create a rule, triggered by your door sensor and add 1 to the virtual meter above
3. hide the door sensor in the device browser.
This should work
This should work
Thanks for the reply.
Sadly it won't do exactly what I'd hope for. I was looking to increment the value, but you need to pay for the rule :(
