Is tamper function of FGK-101 available with Zipabox
Gregory delpu shared this question 12 years ago
I have a FGK 101 sensor from fibaro and I can't succeed to have the tamper working with my Zipabox.
When the sensor is opened, the blue led blinks but it does not trigger the alarm. I have also try to build a rule to test it but it does not work.
The only whay to use it is to directly bind the tamper device shown in the device list with my siren, which is not very handy because it triggers the siren even if the alarm is not armed.
Thanks for your help.
I would have thought that Zipato should add tamper support to these because they target a Zipabox as a sophisticated security system but then leave out the ability to detect tamper - which is a standard feature on all sensors for a much cheaper alarm system.
I've successfully sent a mail and push notification (Pushover) when tamper on Fibaro FGMS is triggered. if you want trigger a siren it's enough change the send message with an action puzzle
