Fibaro realy switch fgs-211 incorrect status offline
I have added fibaro fgs-211 realy switch. it correctly can be set on and off. after a certain time the switch will show offline in the control center, but when manually activated it will work and relay will switch. it is very difficult to asses status of system if dvice go offline when they are actually not.
is there a solution for this or can it be fixed?
Have you tried to re-apply the descriptors to reset the device settings?
Did you move the device after you joined it?
