remote control by http request or API
Chiquito shared this idea 13 years ago
enable to remote control the zipabox by http request or with an API. this feature will enable to remote the box with third tiers software like command fusion or irule, open remote...
Like the vera box from micasaverde
Replies (13)
3
also interested to have this feature to control the zipabox via OpenRemote
I'm also interested in this feature; but also sending commands in simple ASCII telnet, my access control system supports this for example...
Any news on this ?
To control the zipabox via OpenRemote
Did you check out our API or virtual sensors?
What generic remote supports in the best way controlling zipabox, TV and sonos system?
The easiest way to control the Zipabox from the external system is to create virtual sensors and meters within a Zipato system and associate some rules to them. Afterwards, you can trigger those sensors/meters by using http requests from OpenRemote or such a systems....
Second option is to use API, but this is a bit more advanced and requires more programming experience...
@Sebastian
Is zipato planning any another ways to control the box?
For example trough iftttt.com (SmartThings has this option)?
That would be awesome! Veralite has created a free plugin for VoxCommand to voice control z-wave devices and get info from z-wave devices spoken by the computer.
That would be a great improvement for Zipabox, would even pay some money for that function.
Where can I get the http addresses of the virtual devices created and the syntax to use in order to change their state ?
Thanks in advance.
You can get devices url in the parameter of each virtual sensor/meter you create
Then you can directly switch sensor by pointing to this specific url
You can change virtual meter values too
Using a virtual meter, you can for example specify different actions depending of the value of the virtual meter.
Simply create a rule like this:
WHEN virtual meter = 1
set alarm ON
WHEN virtual meter = 2
set alarm OFF
Don't hesitate if you have other questions
when ZIpato write a free pluggin for openremote
An OpenRemote connection would be an amazing step forward for OpenRemote. Maybe one of the OpenRemote developers can create a connection using the Zipato API's.
Bonjour,
oui vraiment fantastique.
J acheterai open remote de suite
Cordialement
