Rule dependent of a light sensor
Aril Wretblad shared this question 12 years ago
How do I create a rule that, if triggered by a Fibaro door sensor (when the door opens) between 08:00-23:00, runs a scene if the light meter (Aeon Labs multisensor) is 3 lux or less?Regards,Aril
Replies (8)
Someting like this:
When Door=open and time now between 08.00 and 23.00
If Mutlisensor Lux=3
Thanks! I kind of understand how to write the rule in text, but I can't seem to figure out how to puzzle it with the pieces in the rule creator. Is this how you should put it together?
WHEN is ok
but then simply put:
IF (multisensor luminance <= 3)
ACTION
that's it!
Like this:
  1. WHEN gallerdorr open AND time between .....
  2. IF (multisensor luminance <= 3)
  3. ACTION
Like this?
If you select a action.....then yes
Yes of course, I noticed a little too late that the action command had reset... but I figured you would see past that.
Anyways, thank you very much for the help. Very much appreciated!
Have a nice evening.
Aril
Have fun.
Hi!
Here is an exampel of a similar rule that I'm using.
Hopfully you will get some inspiration :D
