Benext built-in dimmer support
Bruno MORAZZONI shared this question 12 years ago
I would like to know if the Benext dimmer module is supported by Zipabox.
http://www.benext.eu/static/manual/builtindimmer.pdf
Thank you for your answer
I've tested it with a Zipabox. It's supported, recognized as "BeNext in-wall dimmer module", allows ON/OFF/dimming. But parameters are not integrated yet and energy reporting is stucked on 50W.
I have a problem with this combination. I hooked up 6 x 5watt LED dimmable but sometimes the light flickers. If I remove the dimmer it works fine. Any ideas?
I have the same issue as Damien@Domotique-Store.fr (Energy always equal to 50 W)
Will Zipato correct this issue ?
This issue has been corrected by Zipato (with our help). The device works fine now on Zipabox.
Merci Damien
