Z-Wave Danfoss Living Connect - batteries
I have a problem with my Danfoss valves.
When the batteries show 40% in my dashboard, the next day, the batteries are completely drained ...
Sincerely,
Greetings,
Is this the first time that this has happened to you or is this a recurring problem?
Greetings,
I had to change the batteries of two valves (014G0012).
Have you tried increasing the wakeup interval time of your Danfoss valves?
The wakeup interval is : 30 min.
But it does not explain the sudden drop.
Have you noticed any flashing icons on the valve display when the battery drain occured?
No.
But I have a new valve shows 40 % so I will check.
No.
Hello Mauro,
go to Total devices, click on your Danfoss radiator valve folder and there under Configuration menu is an option to change Wakeup interval.
Regards,
Hrvoje
Hello Mauro,
Regards,
Hrvoje
