Z-Wave Danfoss Living Connect - batteries
domo2014 shared this problem 12 years ago
I have a problem with my Danfoss valves.
When the batteries show 40% in my dashboard, the next day, the batteries are completely drained ...
Sincerely,
Replies (8)
Greetings,
Is this the first time that this has happened to you or is this a recurring problem?
I had to change the batteries of two valves (014G0012).
Have you tried increasing the wakeup interval time of your Danfoss valves?
The wakeup interval is : 30 min.
But it does not explain the sudden drop.
Have you noticed any flashing icons on the valve display when the battery drain occured?
No.
But I have a new valve shows 40 % so I will check.
How do you do it ?
Hello Mauro,
go to Total devices, click on your Danfoss radiator valve folder and there under Configuration menu is an option to change Wakeup interval.
Hrvoje
