intermediate position not working with a FGRM 222 roller shutter
Nicolas Celli shared this problem 12 years ago
I have installed 2 FGRM 222 roller Shutter last week end.
It is working fine when I want to open or close them fully.
But I'm not able to get an intermediate position : when I set the slider to 50 % it opens or close fully the roller shutter.
In the configuration of the device I have setted the operating mode to Blinds with positioning. (BTW there is 2 time the same value, the second one should be "Venetian with positioning" according to fibaro documentation)
Can you help me on this point : I would like to be able to get intermediate positioning.
N.B : I'm only operating them through the zipato's interfaces no wall switch
same problem here. was working fine before. don't know how long it is not working. but today i noticed it when i wanted to close my blind 50%. that didn't do anything. only 0% or 100%.
when I set it at 50% I hear the relay clicking inside the module. but nothing happens.
second edit: after doing the start_calibration_process. it all worked fine again.
Hello Zipato,
Nobody to take a look to this problem???
Am I the only one in that situtation?
Is it working correctly for someone else?
So I have solved my problem without the help of anyone from Zipato.
I'll post the answer here guessing that it will help a someone, someday.
The problem was coming from the calibration process :
I was launching it directly from the fibaro module.
You have to launch it through the zipato application.
I am also facing the same issue with the FGRM 222 Roller Shutter. The intermediate percentages, other than 0 or 100, not working properly. can you give me a solution for this.
Could not get my two new FGRM-222 to be set between 0-100%. This morning one unit (set to learning mode) did its thing and I could use it for a couple of hours. Now, without any changes made they are both back to on/off mode. I'm wondering if this ticket is still 'KNOWN' to avoid spending valuable time in achieving nothing. Yes, all tricks/suggestions are used without success!
I am also facing the same issue with the FGRM 222 Roller Shutter. The intermediate percentages, other than 0 or 100, not working properly. can anybody give me a solution.
