ZIPATO CODE AND RFID KEYBOARD Z-WAV / ZIPATO CLAVIER À CODE ET RFID
Jean-Michel Dupuyds shared this idea 5 years ago
In Progress
with my zipato which wall code keypad do you recommend to activate an alarm and with rfid key fobs.
nb I see that the "ZIPATO CODE AND RFID KEYBOARD Z-WAVE" is no longer manufactured
thank you in advance
Regards,
Bonjour,
avec ma zipato quel est le clavier à code mural que vous conseillez pour activer une alarme et avec des portes clef rfid.
nb je vois que le "ZIPATO CLAVIER À CODE ET RFID Z-WAVE" n'est plus fabriqué
par avance merci
Cordialement,
Hi Jean
Please see all supported keyboards here: https://www.zipato.com/how-it-works/supported-devices?search=keypad
Hello
Thank you for the answer, what material do you recommend: for example is the "Fibaro FGKF-601" compatible with the ZIPATO?
thank you in advance,
cordially.
Bonjour
Merci pour la réponse, quel est le matériel que vous conseillez : par exemple la " Fibaro FGKF-601" est-elle compatible avec la ZIPATO ?
par avance merci,
cordialement.
Sorry for my late answer. I would recommend the popp keyboard. You can also use the fibaro FGKF-601 but only with quick arm + a rule, you can't use this device as a "user-device".
Thank you very much for your answer,
on me also recommend the remote control: AEO_ZWA003 which would be ZIPABOX compatible.
What do you think?
cordially
Merci beaucoup pour votre réponse,
sur moi conseille aussi la telecommande: AEO_ZWA003 qui serait compatible ZIPABOX.
Qu 'en pensez vous?
par avance merci
cordialement
Hi Jean-Michel
Yes, you can also use this remote control, but it's the same. You can use it to arm or disarm your alarm partition via rules (quick arming is required, I think this is a PRO function), but really only via rules. You cannot use this device as a user. Only keyboards with numbers like Popp or Zipato keyboard can be used as users.
