ZIPATO WALL TABLET
Ivan Apostolov shared this question 12 years ago
Hi guys, please tell me how to add the zipato wall tablet to the network? In its manual is written that the wall mount is actually a z wave controller, but i cannot find a way to register it anywhere... In it is written that its serial number (which i have to register somewhere), will appear when i install the zipabox client?! What does it mean? The tablet comes with pre installed zipato app, and when i start it nothing appears... only the zipabox that i have....Please help.
Replies (19)
I have same problem with my Zipato tablet. Can you please explain where seria number will appear?
Hello guys,
go to my.zipato.com and if you don't have an account click on "Sign up". After you register your Account log in with your User name and Password and then you should immediately get a Pop up where you enter your Serial number. After this you will have to log in again.
If you already have an account and you wan't to add a second Zipabox or Zipato wall tablet to your account, after you are logged in click on the drop down menu at the top of the Dashboard/Control Center, select "Add new box", pop up window will appear where you have to enter the serial number. Later you can change between Boxes by selecting one of them in the same drop down menu at the top of the Control Center. Hope this helps.
Hrvoje
Thanks for answer! My problem is that I don't know the serial number. Where can I find the serial number? Is it printet on the label on backside of tablet?
In the tablet manual it says:
When you turn on your Tablet you should get a Serial number.
If you don't get it Click on a Zipabox icon (its listed under Communication) and you should find it there.
Regards,
Hrvoje
can i have more information about that
i own the tablet but i cant find the serial number any where
i think that a photo will be helpfoll
Can anyone who has the tablet make a video review?
Mihajlo wrote:
Serial number is located in Zipabox controller application.
do u mean that i have to have zipato stick ?????
Hello Mohamed,
no you don't need a USB stick the Z-Wave module is implemented in the Tablet just open a Zipato app.
Regards,
Hrvoje
Same for me I have zipato account and a zipa box. How can I add the wall tablett to my current zipabox account. I cant find any serial nr ?
Click on the Zipato logo on the top left corner.
When were. On the app or the website ?
On the web
I should only use it like a android tablett with the app but is it any benefits to use the internal Z wave when you have the Zipabox ?
hope this helps
I will try trt the zipalogo as atilla say, Because the tbalett dont have any serial nr printed I cant use it like the picture.
My other question:
Dont work i only see the zipabox serial nr were can I find and add the zipato sn tablett to my current account
Someone that could tell me were I can find the tablett serial nr or how to configruate it to my account
Is this zipatile? You need to use the zipatile app ro register. If you have any issues, contact support@zipato.com
I can imagine it would be even better if you call them directly.
