chacon modul pairing
Karlito shared this question 12 years ago
hello,
i've got problem for pairing a chacon modul (cmr300).When pairing start the zipabox found it immediatly but don't work.
The zipabox do it for others chacon modul.
My other problem is for a pcr800 oregon rain meter, i've got wrog value (the paring works).
Thanks for your works !!!
Karlito
Things to check:
  • is the CMR300 in range of the Zipabox? (CMR300 antenna may be obstructed if it's mounted inside a wall)
  • are there free slots in the CMR300 ?
Try clearing the memory of the CMR300 and moving it closer to Zipabox.
Problem with PCR800 is known and will be fixed in next firmware.
Things to check:
Thanks for your reply, i've tried 2 new CMR300 and near the zipabox but the probleme is the same.
My CMR300 have got 2 wheel code (1 for home installation A-P and 1 for device 1-16), i tried many different configuration but not work.
I try to add an other chacon device (plug CAYCR-3500 for you but LGDR-3500 for me) and it works great.
I send you picture of them.
Good news for the PCR800 :)
Thanks for your support and sorry for my english...
Karlito
Hi Karlito,
OK, I see what the problem is. We support LCMR-300, which uses a different protocol then CMR-300 (LCMR has no code wheel and uses CoCo protocol). We will add it, but please create a new ticket at support.zipato.com and name it CMR-300 support, so we can track this issue.
Thanks,
Tom
