Big Problem with virtual swich devices (not considered like a virtual switch devices ???)
Not a Problem
I have an issue with Zipato Control center.
Now, when I try to add a virtual switch device. The new device is not registered like virtual switch device. It's impossible to get the URL to control them.
I took two pictures, with a virtual switch device which is OK (created yesterday night) and the other with KO result.
And since when I try to create a new virtual switch device, the result is the same.
And if I check rules creator, I can see one of them is considered like a Actuator and the other like a Sensor ???
Hi Milan,
Let me know, how to build a virtual switch device with activation/desactivation by URL. Because now, I can't do it since yesterday.
Thx.
Hi Milan,
Thx.
Like Milan sad. It's not possible to turn on a virtual switch with a URL. If you want this then use the virtual sensor.
