block "alarm" in rules creator
Julien C. shared this question 12 years ago
could you please explain me what is the objective, and how to use the block "alarm" in advanced menu of rules creator ?
Thank you in advance.
Julien
What do you mean?
You could turn the alarm on or off or make a rule to trigger when the alarm is tripped.
So you can customize your alarm.
I don't think this block is to turn on or off the alarm.
This block (see picture) only works with sensors. There is a lot of choice in "select type".
the Alarm block will be removed from Rules creator because it is no longer functional. Please use sensor puzzle instead.
Regards,
Hrvoje
