Nexa Pro WRR-1
Manuel shared this question 12 years ago
Hi, I got another problem while moving from Tellstick to Zipabox, I can't install my Nexa Pro WRR-1, anyone have a way to fix it?
Thanks.
Replies (12)
Can you try by adding it as LCMR-1000?
I tryed all the NEXA that are in the list without any success, when using the LCRM-1000 the Box says that it was registrated and added to the list but when I try setting ON or OFF it doesn't work, the WRR-1 doesn't react when pairing...
Hi Manuel, please contact us on support@zipato.com, we will take care about this issue.
Wrr-1 pro is a 868mhz module, not a 433Mhz.
No, it is a 433Mhz as I had it connected to my Tellstick and can connect it to a LWST-615 wall switch, wich are 433Mhz.
Ok..
I look at nexa homepage and the new wrr-1 is 433mhz, the old was 868mhz sorry.
Nexa said the the new 433mhz is not compatible with Nexa Gateway.
Ok..
The strange thing is that I got it to work with Tellstick, it was a bit of a tricks but it worked, but now the Zipabox see it, register it but doesn't control it and the support can't help as it isn't supported....
Hi again,
Now after several days getting crazy about my WRR-1 that starts every evening by his own, I found out that it was reacting at the same signal than another device from Zipabox, so now the question is how do I reprogram the other device so I get 2 different connection?
I'm also interested in making the 433 WRR-1 work. I've tried to add it as LCMR-1000, but it does not respond.
Excellent, thanks! :)
I recently purchased the Zipabox Duo. I have a few WRR-1 (433MHz). Were you able to add this device? I can however not see it on the "add device" list.
Thanks for adding the WRR-1 inte the list of compatible devices!!!
