Sunset schedule one hour wrong
Jacob Berggren shared this problem 12 years ago
I have a rule that turns on some lights at sunset but in reality the lights turn off one hour after sunset. I checked the timezone and it's correct. Could this be a DST problem? Is there a way to see what the Zipabox clock is set to?
How did you "catch" the sunset times?
I added a Virtual Weather Station as a device. I then created a rule with a when control and a scheduler sensor.
kGmg2zCknsJ5He7eKYdc
First of all you should check: http://www.wunderground.com for your city. Zipato is using this weather service as a provider for the virtual weatherstation. If sunset is correct you can create a simple rule and save it. In the name of the created rule you will see the date/time of the Zipabox. If this is correct you can create a ticket at support.zipato.com
John
Something must have changed on the server. It has worked the past 2 evenings and I haven't changed anything.
Works fine, thank's Jacob!
