What is the angular variable block for?
Thijs Schreijer shared this question 12 years ago
ef2duYM4ltDoBs6oOCK9
Whether I use it in a 'WHEN' or an 'IF-ELSE' block, I always get an error.
I figured it would be some boolean test, eg. 0 or 'not set' evaluating to FALSE and everything else to TRUE. But while building a test rule, all I got was errors when saving it.
So what is it for?
You can not trigger with only the variable.
You must use the scheduler or sensor/switch etc.
FILES%2f2014%2f06%2ffibaro-smoke-regel-01
If you want to use a variable make it like this:
jCCFjfGKCxO3ComEKeSc
That is actually an answer to another question; https://community.zipato.com/responses/start-a-rule-based-on-a-variable-changing
But still... what is the angular variable block used for then?
I never used it...so can't tell you.
