wall tablet
pascal shared this question 11 years ago
Hi everybody ,
I have bought a new wall zipato tablet, but i'm surprises by the bad screen's quality
Right, when i touche the screen like my ipad , screen seems to be deformed like old screen 10 Years ago!
Every one cet same problem?
For sure it is not the same quality as you ipad. However, there is a protective folie on top of screen, maybe this is causing the screen to appear very bad?
As U can see on the attached pic, when U touch one corner of tab, there is something happen on middle of the screen.
is-it normal?
Hi everybody, I have 2 of them and have the same issue on one of them.
Regards,
Philippe.
There is a PCB on the back side which is connecting the tablet with the wall charger. As the distance between the display and this PCB is very small, when you press the screen a bit stronger, you can see the screen reflection of the back pressure. This is not avoidable with this tablet model, as the space behind is too small.
