Generic 433 receiver?
Claes Wedin shared this question 11 years ago
Zipabox Duo: Firmware 0.9.999.2
I have on/off receivers 433 MHz and the are "Nexa-compatible" (Jula Anslut)...
Which is the most "generic" simple receiver of all the listed devices?
I tried Nexa 1000 it blinks when the add device procedure starts, but then hangs after Device added... Please wait...
The web site also often hangs on Synchronization (although I have 100Mbit fiber)
TIA
Claes
Your guess Nexa LMCR-1000 is no too bad. Nexa / Chacon all use the CoCo protocol. So if a Nexa device is not supported start looking at Chacon or Coco.
However I think that you have a problem with your box. maybe the firmware is not OK but the behaviour you describe is not OK. After Device added and saved you should see a popup synchroniziing.
Synchronizing depend on the number of devices but i have some 30 devices and the process is finished within 15 seconds or so.
Maybe you should contact support at http://support.zipato.com and create a ticket.
Thanks John,
I have only 2 devices added far... So the sync should be fast but sometimes it hangs... I shall continue trying when I come back (leaving for Spain at 6:35 tomorrow morning)...
Regarding the ANLUT devices: I learned how to empty the memory (they have only 2 I think) although it was not described. Enter Learn mode and then press the button one more time!
