Can you create rules based on HOME-AWAY
I run the exterior lighting using rules - no problem. I also want rules to control interior lighting when I am away (that is when I put the system in "away" mode). I have not found any way to make an IF-statement or similar that runs a rule only if system status is away? Is there a way to achieve this?
Just for clarification, I don't want to run a scene where all lights are on 24 h, but have one behaviour when home and one behavior when away.
Any advice on how to achieve this would be greatly appreciated!
/Peter
PS. My wife is currently somewhat upset by the fact that the light go on and off automatically when we are at home! :-)
You can Also make a Sean to turn all lichts of.
(even with a delay of 5 min. or so)
Thanks for the advice, but I don't think this solves the problem (correct me if I am wrong). The proposed rule does something in conjunction with arming partition 1 or with a delay. Let's say that I want lamps to turn on at 5 pm and turn off at 10 pm when partition 1 is in armed status. Can that be done?
Cheers,
Peter
Cheers,
Peter
You need to use the scheduler puzzle.
You must create a rule with two scheduler.
When "scheduler A OR Scheduler B" then...
Scheduler A set to 5pm repeated every day, Scheduler B clone of A with time @10pm
if Alarm status = armed AND light=off then
Set light=ON
if alarm status=armed AND light on then
Set light=OFF
I think it can work.. anyway the this is the right way with adjustments :)
Set light=ON
Set light=OFF
I used alarm device to control home and away settings.
Also i have this included in all rules that i dont want to run if i am not home.
See pictures...
See pictures...
