How to differentiate roller shutter position manually set or automatically set
Bernd shared this question 4 years ago
I have a question to the advanced rule creators:
I am using Fibaro Roller Shutter FGWREU-111 to control our blinds.
Mostly they are set according to temperature, azimut and elevation angle automatically. Sometimes the position is not that what we want to have right in that moment. Unfortunately the rules win at the end and what is manually set is overruled.
To avoid that I have for each blind a virtual switch for automatic mode on / off.
My problem is now how to trigger these virtual switches. I tried it with special positions for the automatic mode eg. automatically opend means position 98 instead of 100 when manually opened. But position 98 is visibly not quite open and therefore is not acceptable from the esthetic point of view.
So, I am looking for solutions to give priority to manually set positions and at the same time fully open / close in automatic mode.
Any ideas are highly appreciated.
Bernd
Replies (6)
First of all, you need to make sure whether the door is powered or not. If the door is powered by electricity, then it is an automatic door. If it is not powered, then check if there is any switch near the door. If there is a switch near the door, then it is an automatic door. Furthermore, for getting thesis defense presentation help, you need to trust professional individuals.
Are you worried about your dissertation and thinking of hiring a Dissertation Proposal Writing Services to get professional support? We can help you at Dissertation Educators for Dissertation Proposal Writing Services.
Did you solve your problem?
Your content helped me a lot to take my doubts MYiClubOnline
I am still searching for some proper solution.
very interesting GoMedicare Cost
