Sensor flood stuck on leak
Luca shared this problem 10 years ago
Yesterday I tested the sensor flood Everspring, but after switching in leak is not returned in a state not leak. and I could not change it.
Hello Ivan,
the model is Everspring Flood Detector ST812
I hope not to have to do the maneuvers that have suggested many times that triggered the sensor .
however, the sensor does not sound and the LED is off , unlike the zipabox continues to signal the flood
This morning I tried again .
the state was leak
I dipped the sensor in water and report mail that I had configured arrived, but the status continues to leak .
In the log, latest activities are all in leak...
I can not take it apart and redo the procedure whenever signaling a flood. The sensor works perfectly and zipabox that does not understand end signal alarm.
There is no way to forcing the state by software ??
I repeat the hardware sensor not blinking and not rings at the moment.
