Power Module
Nathalie Plas shared this problem 11 years ago
I have now the power module connected to my box.The
power module is recognized. I have 1 clamp connected. When starting the
box, it only reads the 4 power module port once, with all values zero
(there should be some value on the camp port) and never again.
Did you disconnected the power from the zipabox? And connect the power to the power module (without a adapter)?
yep did that.
Hmm, than i don't know.
I also had problems with this devices. You better contact support about this support@zipato.com or support.zipato.com.
Please report back the solution.
Alright I will do that. Thanks for your advice.
I have a zipabox 2 and a amper meter clamp conected to a power expansion module on channel one. The problem that I have is that the measures are innacurate, it even gives negative measures or equal to zero, like the devices were not working.
Could you please help me to resolve this issue?
