Rule Creator - Time/Light on
Peter Ede shared this question 11 years ago
i have been reading end reading.
and i cant get a simpel
Time when light on. rule ?
i have i light outside that i want to have on at 15:00 and Off att 09:00
a simpel rule for that ? plz help me.
i have tryd som ruled but i get error´s and things.
and another Q: asto ? is that working ? for stockholm ?
/Peter
Replies (10)
pleas post a screenshot of what you have.
and than we will help you fix it. this wey u will learn it better.
Prova precis men den vill inte spara SUNSET Väder Stockholm ?
vad är tex 19 - 1 ? är det ?
har du en simpel men vara fast tid. att börja med.
Hej. laborera lite till nu fixar jag den. tack för bilderna.
ASTRO får jag lära mig senare den verkar inte fungera.
men fast är löst. bra början.
Translate? :)
You need 2 different sheduler rules. One for on, and one for off. Attached picture have both rules and start time shedule. Do same kind of sheduling for off rule, set time to 21:00. Then light go on 15:00, and off 21:00
Sorry For the swedish.
but now everything is OK. work fine on fixt time.
ASTRO don´t work. if i write Stockholm or like in the pic.
the text just disapeare.
You need to create an virtual weatherstation to get sunset and sunrise. Add device and select "virtual weatherstation" in the list.
If you want exact time for on or off just skip the Astro.
Peter follow the link and you will find a forum in swedish
http://www.byggahus.se/forum/villalarm-hemautomation/225675-zipabox.html
