Z-Wave.Me ZME_WALLC-S Wall Switch supported? ( Battery operated 4-way, inexpensive, surface switch)
Ismo Korhonen shared this question 11 years ago
Replies (16)
Näyttää olevan tarjolla ilman kehystä ja painikkeita. Hinta kiipeää niiden kanssa.
No not supported :(
i found out the hard way...
Battery powered wall switches has to be supported like Z-wave_Me or Duwi,
Please answer Zipato team when these are scheduled to be supported?
Please add support for this wall mounted switch.
Is this supported now?
i really need it to work.
i have 10 Zme_wallc-s Wall switches that i want to use.
You will still have the option to setup a direct connection (so without zipato) between the wall switch and the 2 devices. You can still use the devices in Zipato and the rules. Also when zipato is offline they still work :)
I have it working like this until it gets supported fully by Zipato
Could you please explain in details how to set this up? I am not able to assosiate directly at all
I'm trying to assosiate the switch to 4 Qubino dimmers (Zwave only), one for each dimmer
I got it working as ONE on/off Switch. Will try to write down what I did when I have time. But it would be nice, if we could use all of the switches...
Perfect, please make time soon to write it down ;)
3
All I get is this
6110b63887f1b42bbb81b9ee12bfe138
Same problem. Can you please fix this.
Still Same problem, I cannot use my Duwi 05443 or Z-Wave.Me ZME_WALLC-S wall switches, any light in the tunnel for these?.
Still Same problem, I cannot use my Duwi 05443 or Z-Wave.Me ZME_WALLC-S wall switches, any light in the tunnel for these? Sorry, I did not realise that it does not update the page... too many same comments....
I have a Single/Dual Paddle Wall Switch Wireless from Schwaiger.
This appears as Z-Wave.Me ZME_WALLC-S and it works.
How did you include/connect him to the Zipabox?
The manual does not help me.
Press all 4 buttons at the same time until the LED slowly blinks green.
Now the switch in management mode is.
Press button 1 to include.
Button 2 = Wake up
