New keep online option
David Gonzalez shared this question 11 years ago
On the new interface, on General > Zipabox Settings there is a new checkbox option "Keep Online" what does this? :]
If you put your cursor on the text a popup is shown which explains this functionality.
Nice, didnt see it :)
Thank you!
If checked, Zipabox will automatically restart every 20 minutes when there is no connection with the cloud. This will help to avoid loosing remote connection with Zipabox in case of some software problems.
This is confusing, mine says if NOT checked, Zipabox will restart every 20 minutes when there is no connection to the cloud. Which one is it ?
Does anybody already used the functionality ?
The function has been there for a long time. But the tooltip text was earlier reversed.
I thought I had turned of the function. But when I got a 48 hours break in the fiber net, in the middle of the Swedish winter, my Zipabox restarted every 20 minutes with a empty memory. Total mess.
At last Zipato found out that the tooltip text was wrong and att the function was on, not of.
so in order to avoid 20mn restarts do I have to check it or keep it unchecked?
