ZXT-120, problems to join
I try to join the ZXT-120 IR-extender to the Zipabox. I follow the normal "join device procedure" through the Zipato web interface. The countdown from 60s starts and reply with "device discovred" when I press the programming button on the ZXT-120. Soon after that, the web dialog box re-starts the countdown from 60s again, and goes all the way down to 0, and finishes with a error message:
My ZXT-120 might be a bad specimen or any suggestion what to try?
Had same problem... use old skin and wait till countdown before pressing join button on the IR... try several times
Hi. Your approach worked, even though I'm sure that I also tried the old skin a few times. Anyway, problem solved, thanks!
