Bindings with new web UI
Kantarno shared this problem 11 years ago
With old web UI it was easy to bind modules with the "bindings" tab.
I cannot find it in the new web UI.
Do you have an idea ?
Also some old bindings I've made with the old UI doesn't work anymore. Is it an obsolete function ?
Replies (10)
Is there any update on this? Today I was looking for it but still could not find it.
The bindings have been added to the new UI, but it's not working.. shocking...
I'm not able to save my settings.
What is the advantage with bindings vs rules?
What can you achieve with binding?
Speed?
Speed?
Rules are always more flexible.
Bindings are for the ease of use (no rule programming, just "clicking")
Ea. you click a switch and a light goes on?
Is can you get sync between 2 dimmers by binding them together. Or is it the same latency as with rules?
You can bind a switch to 1 or more lights. And ON and OFF is done. No rule programming.
Not sure about dimmers (No experience).
If you bind a switch to another device, do you have to do that on both devices? Or can you make one switch control 2 devices, and the other only control its on light?
You define the bindings on the switching device (remote, (virtual) switch). Yes you are right.
As i use it i have some rules with virtual switch to turn off all lights. If i add one plug i just bind it to the switch and the rules takes care of the turning on/off witout changing the rule! BUt it doesnt work with new GUI :( sometimes with old?
