New web interface and Everspring ST814
olivier34 shared this problem 11 years ago
Hello Zipato team. I discover the new web application. It looks promising...
I have 3 Everspring ST814 temperature and Humidity meters. They all are displayed in a different way in the "Meters Section":
- The first displays 2 "values" : one "Humidity" and one "Temperature" (Which is what I expect to find)
- the second displays 3 values : one "Humidity", one "Temperature", and one with a strange name """ (just a bracket like that : ") and which display a value that looks like a temperature (but is not the same value as the "temperature" displayed on the meter)
- the Third displays 3 values : one "Humidity", one "Temperature", and
one with name "value1" which display a value
that looks like a temperature value (but is not the same value as the "temperature" displayed on the meter).
let me know what are those strange values on the 2 devices and how to remove them (to avoid confusion).
here is what it looks like :
/qd0SAAAAAElFTkSuQmCC
Nacka 2015-02-07I have same problem (I can see it on my android App)
Humity 25%
Temperatur 21,2 gr. C ( whats thats shits fake temp? )
Temeratur 28,3 gr. C ( its the true temp)
/ W
Hello... still the same problem...
Hello Oliver,
Try to use option "Re-apply device descriptors" inside of device settings. If that fails re add those devices.
Well, I tried to do both proposed action... it did not solved the issue... It even got worse...
- On one, it got included again (I can see it in the device manager list)... But I do not see it in the "meters device tab" ! and I still have those strange 3 values
- For the second one ; I can see it back in the meters list, but which a wrong description !
I dont like this shit everspring ST814
its show
Humity
Temperatur
Temperatur
or in the computor show
Humity
Temperatur
Value2
se attash file from the computor
Value2 = a temporary testing of the meter Ever Spring ST814,
which I performed indoors in the main building, hence the high temporary temperature.
Willard
Hello Willard, thanks for sharing the pain with me... apparently we are only a few with this issue and Zipato team has other priorities...
I may open a support ticket and see If I have more chance this way...
