How to get climate to work with my remotec ZXT 120 IR controller.
Pierre Max shared this question 13 years ago
I tought the IR code to the remotec IR controller using Zipato configuration screen. Those IR codes work perfectly when used form rules creator. I did not manage Climate to use them to control the AC.
Replies (6)
Hi Pierre,
everything is explained here http://community.zipato.com/responses/remotec-zxt-120-tutorial
Remotec ZXT 120 IR will work correctly in Climate only if you have entered correct IR code
From your answer I understand that climate will not work if I do not have the IR code for my AC.
That's correct. If you don't have IR code for your AC you need to learn commands and use rules.
Ok thanks for your answer. Will you allow to use climate when a user uses learn commands in the future?
Remotec ZXT120 have some kind of support to learn codes in some predefined order and then you can use it as if you entered IR code for your AC. We will try to implement that feature to our climate widget. Anyway, you will be informed if we implement that.
Nenad Vojnovic wrote:
Hi Pierre,
Hi, sorry but I don't understand where I have to put my IR code...In the field in attachment? How can I know if the IC code work fine?
