Adding Sonos
Petter Grönskog shared this problem 11 years ago
I notised that Sonos can be added under devices, thats great!
Unfortunately there seems to be a problem when adding my Play:3.
I have tried several times to add my Play:3, when i had the FW version 0.9.999.2i it found the Play:3 but it didn't come up in the Device Manager.
Now it´s have rolled-back to 0.9.999.2a and it´s doesn't even discover the Sonos Player.
Switched over to the old GUI but couldn't even found Sonos under add devices.
What are I´m doing wrong?
Keep up the good work!
Replies (21)
Just seen this option to add Sonos but there isn't an option to add the Play:5.
Will this option be coming?
Try the new Firmware.....
Yes I tried, with the new FW it works to add the Play:3. Thats great! :)
I can now alternate the volume, is there anything more I can do?
I´m thinking of play, forward, TTS, use as an Siren etc.
Sonos integration is just in testing phase, it will come later...
Ok, that sounds great! :)
Thank you for the fast respons.
Cheers!
My first whish for a feature would be to play a uri or tts command to the current player group and then return to whatever state the Sonos system was in before (off, playing something).
Cool stuff like targetting a specific player unit (room) could come later.
Hi their,
I have in any room a Sonos unit (Thanks Ebay) and I'm happy to now that Sonos Zipato integration is a future Goal.
I would like to test it, but unfortunetly I didn't understand HOW TO PUT THE SONOS PLAY 1 or PLAY 3 to INCLUSION MODE ??
When I start Zipato Inclusion I try to press on my PLAY 1 units "mute" + "+" button... and nothing happen ?
Does I do something Wrong.
Or can you please tell me the full procedure or a link to a procedure that explain this manipulation.
THANKS Best regards
Janik Leutloff wrote:
Hi their,
THANKS Best regards
you need firmware which support this integration. This one is still not official.
3
Will Sonos Connect Amp be included in this integration.
Some news about Connect Amp and other Sonos products?
Hi guys,
I've got the last firmware version. I can't add my Sonos Play:3. Not with ethernet or through the Sonos network. It does not work as the in the movie...
Who knows what to do?
3
Any update on sonos support for: Play 5, Connect, Connect amp or sonos playbar?
Some days ago, adding sonos play 5 was released as an option.
Today I tried adding play 5 about ten times, restartet zipabox two times etc...
I am running a play 1, and i works fine (i.e sonos are connected on the same network)
I was not able to add the play 5. Anyone that has done this with success
Works fine for me.
I was able to add one of my two sonos play3.
Tried many times to add the second - without any success now.
I'm able To add Sonos play:1 and play:5. They appear as IP device without end points. I can set them to audio device but can't control them. What am I doing wrong?
I wonder why the Sonos Soundbar cannot be added... I have one and would like to connect to my zipabox.
Dear Jurgen,
In order to resolve your issue please try to upgrade your controller to latest Beta firmware.
Our team have implemented a fix for this issue in the latest beta firmware version.
After you make upgrade try to re add your Sonos once again.
Pero Zovkic
Thank you, updating solved the problem.
I just tried this, updated to beta 0.9.999.8x4, and after discovery it says no devices found.
(I have 2 Sonos Play:3 devices, and a bridge)
any ideas?
