Has anyone played with Qubino relays?
Jki shared this question 11 years ago
There is an additional connector for "digital" temperature sensor. Is it however just Dallas DS18B20? Pin voltages match just to V+, data and gnd. Center pin is pulled up via 4k7 resistor, as data should be. I did inclusion with ds18b20 connected, but it does not show "temperature meter"... Only consumption meters ( as it is dual relay)
Found, and working. It was hidden by default. My bad. But confirmed, that the sensor is DS18B20.
Yep, well done :)
Qubino%20Sonde%20DS18B20
Where did you find the right connector that fits in the Qubino module?
Found the connector. If anyone's interested it's the 1.25mm 3-Pin JST Connector
Working and working... Values are about 4 degrees too low. My current sensor is many years old first series, have to test newer one.
If you want to play with Qubino temp sensor, be careful, there is direct connection from sensor gnd pin to AC live!
Hi, how did you get it visible? I'm trying to get the temperature sensor working on a Vera.
I have no any idea, how it should be done in Vera. With Zipabox this optional sensor is available in device manager, and can be set to visible. Default is hidden.
Fyi: First inclusion must do with the sensor connected. The sensor won't appear, if added afterwards.
