ZXT 120 parameter 27 problem
mohammad hussain shared this question 11 years ago
Hi all,
I am using a remotic ZXT 120 V1.2 module to control my AC using zipabox (york ac), but i cant find where the "parameter 27" in the configuration of the zipabox ! anyone can help me ?
thanks
You cannot add custom configuration for parameters that already exist in the configuration tab.
Parameter 27 is named INFRARED CODE NUMBER in the ZXT-120 configuration tab.
From the device manager, select Z-wave, then your ZXT-120 should appear.
Behind the name, you'll se an "settings" icon, click on that, and then select the configuration tab - there you can send the 27 parameter :)Ub4k0Hkvy7buVloFegxidNs91rTDB9tx7nXDjNrN
Dear Bjorn,
this is what i got when i put parameter 27 , also as shown in the pic there is an IR code field, is this where i put parameter 27 ? or its the place where i put the IR code for the AC ?
Note: i tried both (to put parameter 27 and IR code for AC in the IR code field and both not working).
thanks
Files: 1.jpg
