Copy command for HTTP Request in a rule
It should be nice to have the possibility to COPY an Action puzzle HTTP Request.
I had to create a rule to send some requests to my amplifier. I wanted to send a sequence of HTTP request
As each request have the same method, URL and Header, I had just to change the Body.
It is not an issue but it should be nice to have this command for some puzzle.
Regards,
William
Can you post the Rule and the HTTP request?
I'm trying to do the same :)
If you have saved one rule you can copy the body of this rule by start a new one "when...." and then open the saved one again. Now copy the saved rule body into the new when. Only save now the new body.... and you have a new rule. Works not elegant, but it works.
Hi Lars,
Take a look to this thread : http://www.touteladomotique.com/forum/viewtopic.php?f=14&t=11438#p129064
it's in French but you should find something help.
Regards,
William
Hi Lars,
Regards,
William
