MySensors.org support
Would it be possible to add support for MySensors.org? This way users can created their own devices and interacht with the Zipabox.
I guess the easiest way to implement is by using the Ethernet solution for the master controller.
this and autovera plugin to tasker is the only reasons i still hold on to vera and consiering what one to use in the long run. Thumb up for this ide
HI,
Make the arduino to be seem as oregon device for example ... ?
Or do a http post with an internet wifi shield or wifi device on the arduino.
I will try both next.
Look at this
http://www.connectingstuff.net/blog/encodage-protocoles-oregon-scientific-sur-arduino/
HI,
Look at this
Wifi shield is way more expensive than the RF2.4GHz modules for the mysensors system. Simulating a Oregon device is just a dirty solution in my opinion ;-) Would be better to allow a real custom build platform like the mysensors system. A bit more DIY with Zipato and Arduino would be great :)
I agree would be perfect to have an integration with mysensors via arduino gateway either by ethernet or usb.
Any news?
I have mysensor gateway.
Is it time to switch to Vera controller?
Best regards
Peter
Any news?
Best regards
Peter
Any news?
Best Regards
Peter
Any news?
Best Regards
Peter
I fully support this idea. Zipato seems a bit too limited with regards to general interface incl. the way the 433MHz module works. Better IP support (network discovery, UPnP and eg. ChromeCast), MQTT (on the way I understand) and a Node-Red node would be highly appreciated. I'm sure a lot could be done as it is, but it's not for "everyone" to achieve it at present.
