Horstmann HRT4 - No more value showed in the widget
Since yesterday, in the old dashboard there is no more value of temperature (set, room) in the thermostat's widget.
Horstmann_15122...
Hello Stephane,
Can you see any values in event log for this device?
Hello Stephane,
Hi Antonio, yes I can see event log for this device. This problem occure only in the old dashboard and everything work in the climate widget.
Old user interface is becoming obsolete and we will not debug it anymore. Please use new user interface for further use.
I have the same issue. But I don't think it is related to new or old dashboard. I see reports in events but with the label Value1 instead of Temperature . The IOS app doesn't display the Thermostat in meter section. But the climate widget is running well!
Yes indeed.
It is now ok but I had to de-install / re install the Device.
Yes indeed.
