Tasker examples
Using the Imperihome app plugin with tasker let's you create many individual and automated scenes and tasks. Some examples I have used are attached below. What can u do?
I also use imperihome app with tasker. I have also set up HTTP devices on zipabox for direct calls from tasker
-Automatic disarm and arm of house based on cellphone's for all family members location (wifi connected currently used but can be done as well with geo)
-Voice control via autowear, autovoice and tasker with imperihome sceens (sadly i can not build a compleate solution since imperihome does not support single device action via the integration and i do not want to have 400 scenes)
-Automatic night-mode (turn off lights, tv and more) when phone/watch is connected to charger between certain times of the day
-NFC tags via trigger/tasker to perform zipabox events and switches
-Morning alarm and weak up will not activate if any cellphones are at home (controlled via tasker to zipabox)
Let me know if you need any info how it was done
If someone knows how to make tasker use zipato API calls please post here. i have so far not manage to get it working
Also to zipato team, why not update the android app with tasker support so we can don't need to use 3ed party app for this.
With tasker I'm testing if I am in my home wifi range . If yes, I trigger a virtual switch and....
open store in summer after work when I'm comming home
put on the frontdoor light for 3 minutes if after sunset
Also, if back door is open, Zipato send me an sms, and tasker read it with key word and activate data and open my ipcam.
better start with this tasker then...seems nice to combine these various scenarios...
Jacob, you need to jailbreak the IOS. On the cydia you will find something similar to Tasker. Maybe not as advanced but there is.
It is called SBProfiles. Not as advanced as Tasker but can also do some of the things.
or just use IFTTT.
or just use IFTTT.
