Zipato Trio Sensor
Oliver Schwab shared this question 11 years ago
Hi there,
I have a few Zipato trio sensors and still have some questions.
1) Light sensor seems not to work very well as the max value is about 20%. Is there a way to adjust this?
2) In the configuration setup there are options for the operation mode and multisensor function switch (see attached file). What are these for? Unfortunately I cannot find any documentation about this.
Any help is appreciated.
Oliver
1) What do you mean with max level?
2) It's in the manual. Look here:
http://support.zipato.com/index.php?/Knowledgebase/Article/GetAttachment/97/3107
Hi HeroS,
thanks for point 2). I had checked several time the manual but never made the connection to the settings in the Zipabox ....
Max level means I never get a value higher than 20 although it is full day or the lights are swichted on. So I am wondering if there is a way to calibrate the light sensor.
Regards,
Oliver
