rstp not working with ebode IPV38P2P
Christophe shared this problem 11 years ago
I have a HD IP camera (Ebode IPV38P2P)
It works fine with VLC, but not with Zipato
rtsp://mylogin:mypassword@192.168.1.14/videoMain
could you help me
Replies (6)
Any advice ?
  • What does not work exactly?
  • What is the error you are receiving?
I have setup multiple IP cams on RTSP and they work fine. I am running the RTSP stream on a separated port when streaming. See attachment. So you may have to check your IP cam settings as well to make sure you use the right ones. The player Zipabox is using can stream RTSP without problems.
I can't see the stream
it does not work with :
neither
rtsp://192.168.1.14/videoMain
nor
rtsp://192.168.1.14:554/videoMain
how can I check what's wrong ?
on android i have the error message : streaming launch impossible
try
rtsp://192.168.1.14//user=${username}_password=${password}_channel=1_stream=0.sdp?real_stream
or
rtsp://192.168.1.14//user=${username}_password=${password}/videomain
top one works for me (with my IP of course) but might not work for you......
Thank you, but the 2 solutions don't work.
With my IP cam, the right way to have the stream is : rtsp://mylogin:mypassword@192.168.1.14/videoMain
I've opened a ticket
