Automated rule creator?
Jacob Wiqvist shared this idea 11 years ago
User should not need to know any thing about bindings, endpoint or group, Zipato could have a automated rule creator? That asks the right questions, then the user could learn to creat ruls by them self easier, buy looking on the automated rules.
  1. What name of your new rule do you want?
  2. What switch do you want to use? (List with switches appear)Also virtual switches and sliders could appear or be created in this stage?
  3. Is the switch ON or OFF or MONO STBLE? (List will appear) If you choose MONO STABLE a new question will appear: a. Is the switch Normally OPEN or Normally CLOSED?
  4. What light, socket, rule or scene do you want to control? (List will appear)
  5. What do you want to happen if you press and hold the switch? (List will appear)
  6. Do you want something to happened when you double click? (list will appear)
  7. Do you want something to happened when you triple click? (list will appear) And off course if Zipabox dose not see long press from the device, it only see trigger, that option will not appear. Example. Nexa remote?
  8. If you want to dim a light as long as the switch is hold like the Qubino dimmer or if you want to dim the light like Nexa with a second push that will start a dimmer cycle, you should be able to do this.
Then if you want to create advanced rules with a simple push of a switch or double tap it should not be that hard to create!
Off course we need good explanations of what different things is what on my.zipato.com.
I totally agree about explanations, samples, tutorials etc.. We are now working on it, and at some point we will integrate them into the UI.
However, I personally disagree that making rules should be simplified more than it is. Our wish is to teach customers how to use it. Once they understand basic principles, they will be requesting flexibility and power (as you do). So generally, simplicity is important for the first week or two, flexibility and power is important for the rest of the life. And simplicity is unfortunately, limiting the flexibility and power:-(
However, we do have Package wizard now for beginners which are not interested in rule creator and other home automations buzzwords. They can just follow the wizard and get these rules up and running with their own device (of course, these rules are pre-configured already by us).
Anyway, this is my personal opinion, final direction will depend of other's opinion too.
btw. thank you for useful suggestion!
Then a lot more explanations is needed. And example rules with all the elements is doing in Rule creator. "Some one that explain more in the videos, piano is nice but does not explain much" :-)
And if you saw my video of the simpel App TellEvent and what it can do. That is missing in the app and not possible to do with timers and schedules. Simple stuff need not rule out advanced.
I am very interested in the rule creator but also in package wizard. How can I try it now?
I am think of rule creator like this pic:
a78d5ad05ede5e6db3a4b1cf37423edb
But maybe I am thinking wrong?
Just try to create some rules in FHEM....then you know that this rule creator is the easyiest Thing you ever saw.....
Then why haven't you answered this?
https://community.zipato.com/topic/simple-switch-turn-on-socket-problem
It is a simple thing I want to do!
I bought the Zipabox without any knowledge about programming at all. Started playing with the rules creator that is available and know a lot more now. I even managed to get my alarm to switch to armed when my wifi network is out of range of my mobile phone, and disarm when I am near my wifi. :-) Though this requires Tasker on an Android phone. With Tasker and Zipabox combined the possibilities are endless.........and not too difficult.
