thermostat function on version 0.9.999.6 don't work?
Not a Problem
I have a problem where with update on
newer version function Thermostat doesn't work anymore.
With direct functions I can control AC
with IR extender normally, but if I run program for thermostat nothing happens.
It doesn't change the AC and I tried with
functions that AC is Off and On.
Does someone have the same problem. I have
tested also on one other location where it worked before and it does not work
with new version.
Can guys from Zipato check that - looks
like problem is in application (new version) and not in settings.
Thank you.
Hi Milan,
thank you for your answer. It will be opened shortly.
Kind regards, Edi
Hi Milan,
Kind regards, Edi
