thermostat function on version 0.9.999.6 don't work?
Edi Sirec shared this problem 11 years ago
Not a Problem
I have a problem where with update on
newer version function Thermostat doesn't work anymore.
With direct functions I can control AC
with IR extender normally, but if I run program for thermostat nothing happens.
It doesn't change the AC and I tried with
functions that AC is Off and On.
Does someone have the same problem. I have
tested also on one other location where it worked before and it does not work
with new version.
Can guys from Zipato check that - looks
like problem is in application (new version) and not in settings.
Thank you.
Hi Milan,
thank you for your answer. It will be opened shortly.
Kind regards, Edi
