Invalid Siren Rule
Mollari Robert shared this idea 10 years ago
Hi I need some help. Zipabox says the following rule is invalid. It's making me crazy ;)
6bbcf2e82b9690ebbaec7e26ab7f4a03
Hope someone can advise me. Thanks!
Looking at your initial post picture i would changeonly the first part
WHEN DOOR OPEN change to WHEN DOOR ANY
Before the IF and after the when you might need to add "JOIN"
Regards,
Slashroot
Replies (13)
Try tovremove the if condition.
Thanks but doesn't work either.
09f5e588cddf0046909a383ff48712b2
Or
e6055c6735d63d3c3b2616c928f40750
Or
Probably need to contact support. Raise a ticket. I have not seen this error message before
Regards,
Slashroot
I got the same issue yesterday. After several hours of investagation I found the root cause.
When I save the rule i got the same issue than you, I have checked my rule all was OK, so I have re-select the condition again ( open or close) and my rule became OK.
Try it and tell me.
In which language are your in your dashboard?
Fabrice
Could you give me the name of siren you use?
I use the Zipato siren and the language is English.
Try to not use the repeat bloc one time. Maybe it's it ?
include a message in the repeat block for testing, if it is working. And test with longer wait. To short time between two operations may produce a z-wave problem.
44edad53a5b15a7a42b2ee1ef51b4cdb
This rule works. Thanks for thinking with me!
