Invalid Siren Rule
Hi I need some help. Zipabox says the following rule is invalid. It's making me crazy ;)
Hope someone can advise me. Thanks!
Looking at your initial post picture i would changeonly the first part
WHEN DOOR OPEN change to WHEN DOOR ANY
Before the IF and after the when you might need to add "JOIN"
Slashroot
Slashroot
Try tovremove the if condition.
Thanks but doesn't work either.
Or
Or
Or
Or
Probably need to contact support. Raise a ticket. I have not seen this error message before
Slashroot
Slashroot
I got the same issue yesterday. After several hours of investagation I found the root cause.
When I save the rule i got the same issue than you, I have checked my rule all was OK, so I have re-select the condition again ( open or close) and my rule became OK.
Try it and tell me.
In which language are your in your dashboard?
Fabrice
Try it and tell me.
Fabrice
Could you give me the name of siren you use?
I use the Zipato siren and the language is English.
Try to not use the repeat bloc one time. Maybe it's it ?
include a message in the repeat block for testing, if it is working. And test with longer wait. To short time between two operations may produce a z-wave problem.
This rule works. Thanks for thinking with me!
