climat widget what means input endpoints ?
Jacques shared this question 10 years ago
climat widget what means Input endpoints ? what's for ?
thanks
I also want to know what a endpoint in general is?
Some explanations of everyhing in the web UI would be good and maybe reduce this kind of questions on the forum.
You can find info here: https://community.zipato.com/topic/climate-widget-question-what-is-a-heating-input-is-it-not-the-thermometer
On my side, I use a "Z-Wave Secure Wall Thermostat with LCD display" device (known also as SRT321 or Horstmann HRT4-ZW THERMOSTAT) and I can select the desired temperature from the device. It can be considered as a secondary controller (input) of the climate widget.
I have just made a vitual thermostat for deshumidification (output endpoint=vmc and hygrometer are set), but, how can I control it ? I can only control temperatures in my schedule, no humidity percent....same for ventilation control.
I've read the post about input endpoint, but I don't understand anything. I can only select remotes or switches or thermometers but there is no interaction, so what's for ?
