Lost of syncronization of FGS
Zipato guru shared this problem 10 years ago
Dear Ziapto community .
I Installed some FGS and FGD few months ago everything is right.
But today when i wanted te expand the Smart home i tried to add some FGS.
I included them to the Z wave network after wiring the FGS next to the walll box and i turn off the power supply for wiring reason there is lost of synchronization with the Zipabox !!
It's strange because i turned off power supply for the Switches i have installed months ago and once the power supply come back they will be automatically updated as online.
I think the problem is a bg from your server.!!
Could please help and assist. I'm under pressurec regarding my guest this is a bad reputation for me a zipato installer and for you as brand .Please solve the problem uergently.
Reagards
Moalla .H
Try a network heal...if it does not help, try configure node. If this does not help. support.zipato.com
how to do network heal from the dash board?
You go to "Zipato box settings", scroll down and click on "Network heal".
For configuring node you need to go to device browser, click within Z-wave network on the highest level settings for the device, click advanced and click configure node.
Thank you Attila that worked fine .
But do i have to do that every time i add an FGS or FGD.
We are not used to do that since months ago as i did with some FGSi installed in the same house i'm working on today or this is a new server issue from zipato?
why the old FGS installed do they turn online after power spply turns off again and the new FGS i installed today don't turn online atomatically after power spply off?
It's not good or nice to do (hel network) that every time the power is turned off!!!
An automation heal network is requested and better .what do you think?
Please need an explanation for that
Thank yo very much
Hi, glad it helped. Obviously this is a temporary fix then. Thy the node configuration I described as well. What you can also try is to exclude and reinsurer the new module in the old version. Some people reposted previously that using the old mode did only help. This is definitely a bug and needs to be sorted by zipato. Open a ticket on support.zipato.com
