NodOn Soft Remote and NodOn Wall Switch
A year ago i bought two ZME_WALLC-S, but there was and is still no support for those.
So now i bought a NodOn Soft Remote and a NodOn Wall Switch to se if they work. Everywhere i found it said Zipato supported. And i can include them without problem.
But it seems that i need help writing rules, cause i can't get anything to work.
Yesterday when i tried i could do a rule like "When button 1 1-click"
Today the option 1-click is gone and i have on, off, decrease, increase, setvalue...
I would like to turn on if one click and dim up if long press or double press.
Anyone got these to work?
Last week i got some samples. Going to test them asp but they should be supported.
Ok, i used the wrong element in the rule. I used the "Group 2 - Button 1" and so on for all the buttons.
But the one to use was the single one that i didn't think of using before. The one with out button in the name.
What are the "Group 2 - Button 1" used for?
And can anyone help me with how i write a rule that does this:
When "+ Button Held" startchangeup until button held is released then stop change.
Dear Jocke,
Do you still have your ZME_WALLC-S? It seems some progress have been made for supporting them. It seems that is same hardware inside than for the remotes kfob-c ( https://community.zipato.com/topic/support-of-popp-kfob-c-4-buttons-keyfob). Could you have a look if the situation has changed?
Otherwise I am also interested to get a sample for handling correctly a long press on a button.
Dear Jocke,
Hi , since yesterday I have a NodOn Soft Remote, but I cannot get it included at all.
I have the same problem, cannot include.
I have tested both using new and old UI, no difference.
Edit: Selecting Exclude mode on the remote in the old UI got it to include finally!
I was able to include them if i put them next to the zipatobox when i did the include.
The soft remote works fine. But the nodon wall switch is so slow so long delay until action. And first press on a button feels like a wakeup cause it never triggers anything.
